Hi all, I am new in this. Please guide me through. Thanks in advance. WW 10.1 with below: (1) PLC - AB CompactLogix with EIP. (2) WW 10.1 with SQL Express database on Windows 7 Pro 64 bits. WW Archestra event records that:- (1) Most data records stored correctly to database. (2) Occasionally, some data failed to be logged with error captured. - The WWSQL.dll warning message appeared at the vent log. - Data from PLC is triggered to WW, does not logged to database while above error occurs. - Log file is captured and will try to upload if possible to. Please help and guide me through. Thank you so much. Robin
