Hello All This is my first Transaction Manager project. I have a working configuration in Transaction Manager 10.20 that successfully writes PLC Data to an SQL 2012 Management Studio DB based upon a trigger event. The only problem I'm having is with writing String Datatypes to my SQL DB. For example, I have a "Serial Number" that is a string variable in my Allen Bradley ControlLogix PLC. In turn, I have the "SerialNumber" field configured in a SQL table as varchar(length 14). The Transaction Manager connector only shows SerialNumber PLC tag as Data[0] thru Data[13] under Data Points. In Transaction Manager I entered 14 in the "Elements" column for Serial Number. I assumed that would be Data[0]..Data[13] But when I trigger my transaction, the SQL Database field for SerialNumber is a value of "11"...which is the string.LEN property, (current string length of Serial Number is 11). How do I configure Transaction Manager to write the actual ascii value for the SerialNumber string to my SQL database instead of the string length? thanks Jay
