vodoca Posted August 19, 2015 Report Posted August 19, 2015 (edited) Whe have STB NIP 2212 with DDO3705 connected via optical ethernet with Modicon Momentum M1 PLC. When I disconnect ethernet cable from STB NIP 2212, the machines connected to DDO3705 go off immediately. Is there any option how to configure, how long are output bits persisted, similarly like on ENT 110 01? There I can setup 0 (indefinitely) to 60 seconds. Edited August 21, 2015 by vodoca
Quant Posted August 20, 2015 Report Posted August 20, 2015 (edited) Hi vodoca, you can choose between fallback mode and hold last value and set timeout for some DDO via web browser. Just login with webbrowser to your NIP and set this settings. Edited August 20, 2015 by Quant 1
vodoca Posted August 21, 2015 Author Report Posted August 21, 2015 Yes, thanks, found it too after all, but on older NIP with exec version 2.0.2 there was in the web interface no choce for "Link failure mode" - does it mean it is "Holdup" by default? On 3... firmware I have setup Link failure mode "Holdup" and 5000 for 5 seconds.
Quant Posted August 21, 2015 Report Posted August 21, 2015 normally, the default value is "Fallback mode", so that after link down all outputs going to 0. 1
