joaco1993 Posted August 20, 2015 Report Posted August 20, 2015 Hey , im new to the forum and having some trouble when deploying a managed app from archestra IDE to another machine. This is my setup and error: I have on both machines the same username and both under the same domain.. Also i can ping both machines from both sides, using the IP and the Nodename however now , when i want to deploy i get error : cannot get the target PC on the network.. However if i search the node in Winplatform I can see the other machine under the domain.. Any ideas ?? thnks !!
kaiser_will Posted September 11, 2015 Report Posted September 11, 2015 Both PCs have unique IP addresses, I assume. Do they both have different PC names? If you cloned a PC and changed the IP address, this may be the issue. What application is generating the error?
