Guest achkars Posted October 25, 2004 Report Posted October 25, 2004 I'm running a Premium with PL7 PRO v4.7 I'm looking for a way to create a file (text, csv, or anything else) on the cpu running PL7 that copies a number of variable values on a regular basis (ie. every 10 minutes). Any insight would be appreciated, since I cant seem to find a clear instruction list on the modicon website. Thanks in advance, Stephane Quote
Crossbow Posted October 25, 2004 Report Posted October 25, 2004 Wow... they're up to 4.7 already? Last one I had was 4.3. I don't know of a way to save to a text file, but I thought there were commands to write data logs to the memory card (if equipped). Quote
Chetan Patel Posted December 6, 2004 Report Posted December 6, 2004 I have done this in Version 3.4 and 4.3 Select the station in PL 7 program right click it and use Transfer Data option. Quote
undercontrol Posted August 17, 2005 Report Posted August 17, 2005 It's 4.5 now, take it easy. You can do it in 2 ways : manual and automatic. For manual, you could transfer data by yourself. For automatic, you're talking about data logging here. You could use OFS and log it to MS-Access. Quote
