I have objects like this $Template1 -Instance -Instance -Instance -Instance -Instance -Instance $Template2 I want to move the instances over to the second template (they should derive from that template). How do I do this? Edited by veon
Instances of a template are children of that template.  If you create a second template it will have its own children that are unique to it.You can't simply "move" instances of one type template to another template. You will need to delete and then re-create instances on the second template if you want instances for the second type template.
You can create a "derived" template  the first template then any UDA's, Scripts, etc belonging to the parent template would then be inherited by the child template.
I hope this clears things up.
Edited by cbvance
