RDA Posted October 13, 2015 Report Posted October 13, 2015 HALLO THER IN SOMEON WHO HAS OPERADEC CX SIMULATOR WITH SERIAL EMULATED COM DE REALLY TURNS ON COM PC DE PC WHERE THE SIMULATOR? THANK YOU
RDA Posted October 13, 2015 Author Report Posted October 13, 2015 FRON TEST DONE THAT I SEE THOW IT WORK THE SIMULATOR AD SLAVES SERIAL AND WORK IF COM CONFIGURED AS SISPLAY
PdL Posted October 13, 2015 Report Posted October 13, 2015 Seriously, I can understand a lot, but this goes above my head. Sorry.
RDA Posted October 13, 2015 Author Report Posted October 13, 2015 Sorry my language, repeat the question, do you know the simulator cx send the serial pc which is turning the control that are written in the plc and posted on serial such as e txd rxd
PdL Posted October 13, 2015 Report Posted October 13, 2015 If I understand correctly you want to use CX-Simulator to test TXD/RXD instructions? I have never done it, but according to the manual it should be possible. Not sure however if you can also test actual live equipment connected to the PC.
RDA Posted October 13, 2015 Author Report Posted October 13, 2015 i tried tested, the serial work as slaves nt link, also function if com cx simulator and mode "display", as "real com" does non work, where i'm wrong. Greeting.
PdL Posted October 13, 2015 Report Posted October 13, 2015 Are you trying to connect an HMI to the computer running CX-Simulator?
RDA Posted October 13, 2015 Author Report Posted October 13, 2015 no I'm trying to connect one of the serial Modbus slaves plc simulated using the funcion TXD e RXD.
