How to power series six modules on bench?
Hello GE experts, need help on module supply voltage pins, i have some Input modules lying around and i want to power them up off the rack (on bench), thanks...
There may be a manual here: http://www.plcs.net/downloads/
Thanks Russ, i have the GEK-96602A manual but there's no instance of backplane power rails there... We have only one PLC unit and cant afford the downtime just to trace and take notes of the power rails, I guess il just have to wait for it to fail hehehe....
The LEDs on input modules are on the field wiring side, so if you make the proper connections they should light up when you apply a signal. I just verified that with an 8 circuit 110 VAC Input module.
Thanks steve, our plc has failed, maybe bec of old age... http://forums.mrplc.com/index.php?showtopic=29518 any help from you guys is greatly apreciated thank you...
R I P Good old Series 6, best 4-bit PLC ever made! R I P
