308guru Posted October 29, 2004 Report Posted October 29, 2004 I was wondering if there is a way to view the Main Device Memory Online? I would like to watch as data locations change but the only way I know how is to download it each time. Is it possible to view it real time? Thanks, Mike Quote
Crossbow Posted October 29, 2004 Report Posted October 29, 2004 Well a bit more info will make for a much more accurate answer. In GX-Developer, all you have to do is in the Online Menu, go down to Monitor, and pick Device Batch Monitor, or Entry Data Monitor. The Device Batch Monitor you input one address and it shows a batch from there on. The Entry Data Monitor you type in each address you want to monitor. Then in either one, click the Start Monitoring button on the right hand side and you can see everything in the PLC as it changes. Quote
