Hi I just buy brand new 6ed1052-1md00-0ba8 (Logo 8) PLC and a USB-PPI logo cable from tradeindia.com, I am a embedded system hobbyist and fond of exploring embedded system things such as microcontrollers, FPGAs/CPLDs etc, but this time I want to try PLC. Now my problem is that I am a pure newbe to PLCs, I have a 12 V 1A DC adaaptor can I use it as PLC power supply? and input for switches? How to program my Ladder logic, function block to my plc using PLC Cable (USB) and Ethernet cable. ? Can I use Logosoft7 or only version 8 ? is my usb-ppi cable is useless, can i program my plc by my usb-ppi cable Please guide me how to get start with my PLC?, is there any step-by-step tutorial? because I googled tutorials, getting started but i am confused. Please reply soon Thanks in advance.
you can found examples of logo oba7 and oba8 here.https://w3.siemens.com/mcms/programmable-logic-controller/en/logic-module-logo/application-examples/Pages/Default.aspx7 and 8 series are connected to pc with ethernet cable.
Make sure the Logo you have is 12VDC, not 24VDC or 120VAC. And PPI is not used with Logo, that's for S7-200. Hundreds of examples available from Siemens.
Crossbow, I guess you are a bit in confusion. I know LOGO sience many years, it can run for sure on both situations of power supply: 12V or 24V. I agree with you that PPI cable is not suitable for LOGO. To communicate with that 8-th serie of logic controller you only need a standard ethernet cable. dekor.
Hi, I wonder if the incompatibility of IOs modules from previous versions of LOGO with CPU LOGO! 8 is only the question of dowel pins between the bases and there is also a hardware incompatibility. If I break the plastic pin fitting 6ED1055-1CB00-0BA0 module and connect it to the bus LOGO! 8 will be compatible? Or have even acquire 6ED1055-1CB00-0BA2 module? Thank you very much!
