Stevic Posted December 6, 2015 Report Posted December 6, 2015 I'm having a problem creating variable tag array in Citect SCADA V7.40. I looked every possible help, user guide... but no matter how i set array I cannot change value of any element of array beside first one. I configured my variable tag as shown below: Tag name: TestArray I/O Device: Internal (it's an OPC Factory Server) Address: V500[5], %MF4000[5], I2[5], F2[5] (I tried every one of these for REAL or INTEGER type based on user guide/forum posts) Data type: REAL, INTEGER I tried every one of these but without success. If i try to set value of variable tag array element, example TestArray[1] and TestArray[4], by typing value in Number field (in Citect Runtime) every element of an array is giving me message #ERR, except first one. Other than that in Citect Runtime in All variable tags window, I can see TestArray tag as a single tag, not as an array Note that i'm not using these tags in Cicode but in Graphic Builder / Runtime. I need about about 50 user defined value tags to be sent to SQL DB by SCADA so remote PLC can read those values in order to define state of outputs. I would highly appreciate any kind of help, any tip. Thanks in advance! 1
mhasanpour Posted April 3, 2023 Report Posted April 3, 2023 I have the same problem. I am using Citect Scada 2018 version.
