Hi Chuckyegg,   Interesting question! I think that you have to check the portforwarding in your router. In the NAT settings you can forward an external request to an IP number of the PLC with the same portnumber. It could be a problem if you change the port 5556 to an other number like 5557 because I know that in the FX3GE the port 5556 is a dedicated portnumber. I don't know if the type that you mentioned FX3G is the same as FX3GE. The GE type is limited in his features compared to a FX3U model. Just try and find out if you connect two PLC's to the router witch each an independent IP and one with port 5556 and second 5557 or 5551.   Best regards, Theo V.
