Bigha Posted December 25, 2015 Report Posted December 25, 2015 Hardware & software HMI - / GT Designer 3 ver. 1.113 T PLC - Mitsubishi FX5 32 MT / GX Works3 ver. 1.019V Error HMI shows "Comm error". i.e., The HMI isn't getting a response from the PLC. IP addresses are all correct and ping (and can be programmed) OK. These settings are correct? Many thanks.
altan Posted December 27, 2015 Report Posted December 27, 2015 Hello Bigha, Here was changed system and my .pdf file is removed from other post. I send you some example that i have. As i see you have error in "Controller type". It Shoud be iQ not FX. I think Communication Port No Should be 5001. Upload my program it must work P.S As i remember for HMI GS2107-WTBD have additional GS Installer in Installation disc. So install GS Installer. (find it) Best regards: Altan Sadak P0382014n2.GTX P0382014n9PID44n16.gx3
Bigha Posted December 27, 2015 Author Report Posted December 27, 2015 Hi Altan! Thanks for the reply! I will look definitely!
Bigha Posted April 6, 2016 Author Report Posted April 6, 2016 (edited) Step 1 – download the latest version GT Designer 3 from the Mitsubishi website. I use the version 1.145 BStep 2 - Settings for GT Designer 3 Controller Type Melsec iQ-F Driver: Q17nNC, CrnD-700,Gateway And other settings like the screenshot: Step 3 – the settings of GX Works3: In this project a PLC and HMI I've connected through the switch, if you use a router, then you need to add the ip address in settings. When using the router fill project occurs without a cable. Edited April 6, 2016 by Bigha Thank you very much Altan
anishb92 Posted November 26, 2017 Report Posted November 26, 2017 can u mention the link for GT designer 3 latest version download !? i am stuck in older version of software ! it will be of gr8 help, thanks
ST Kyle Posted November 27, 2017 Report Posted November 27, 2017 You can get the latest version from the download section on Mitsubishi's website.
