abdoon89 Posted January 21, 2016 Report Posted January 21, 2016 Hello Everybody I have a problem connecting FX3U to F700 using RS485 inverter protocol. I built the PLC example provided in the Data Communication manual to run the inverter, and then modified all required parameters in the inverter. Yet, as I run the PLC it says that the inverter is not responding. What could be the source of this problem? Is it a must to use twisted pair cables? as I am using ordinary wires.
Crossbow Posted January 21, 2016 Report Posted January 21, 2016 As long as send and receive wires are correctly connected and parameters are set, it should work. It's been a while, but I know I used the sample code in the manual to set up my first one many years ago. 1
Dixson Posted October 2, 2017 Report Posted October 2, 2017 I have the same problem I would appreciate your help
kraykov Posted October 3, 2017 Report Posted October 3, 2017 To localize the problem you must: - provide information about the inverter settings you have made; - provide information about the application program; - cable length between inverter and PLC.
