SMOD New Version 1.0.1
smod
smod is a modular framework with every kind of diagnostic and offensive feature you could need in order to pentest modbus protocol. It is a full Modbus protocol implementation using Python and Scapy. This software could be run on Linux/OSX under python 2.7.x.
Feel free to make pull requests, if there's anything you feel we could do better.
Summery
SCADA (Process Control Networks) based systems have moved from proprietary closed networks to open source solutions and TCP/IP enabled networks steadily over recent years. This has made them vulnerable to the same security vulnerabilities that face our traditional computer networks.
The Modbus/TCP protocol was used as the reference protocol to display the effectiveness of the test bed in carrying out cyber attacks on a power system protocol. Modbus/TCP was chosen specifically for these reasons:
    modbus is still widely used in power systems.
    modbus/TCP is simple and easy to implement.
    modbus protocol libraries are freely available for utilities to implement smart grid applications.
You can use this tool to vulnerability assessment a modbus protocol.
Demo
Just a little demo showing off the basics
root@kali:~/smod# python smod.py
 _______
< SMOD >
        \   ^__^
         \  (xx)\_______
            (__)\       )\/\
             U  ||----w |
          --=[MODBUS Penetration Test FrameWork
       --+--=[Version : 1.0.1
       --+--=[Modules : 14
       --+--=[Coder   : Farzin Enddo
          --=[github  : www.github.com/enddo
SMOD >help
 Command  Description
 back     Move back from the current context
 exit     Exit the console
 exploit  Run module
 help     Help menu
 show     Displays modules of a given type, or all modules
 set      Sets a variable to a value
 use      Selects a module by name
SMOD >show modules
 Modules                              Description
 modbus/dos/galilRIO                  DOS Galil RIO-47100
 modbus/dos/writeSingleCoils          DOS With Write Single Coil Function
 modbus/dos/writeSingleRegister       DOS Write Single Register Function
 modbus/function/readCoils            Fuzzing Read Coils Function
 modbus/function/readDiscreteInput    Fuzzing Read Discrete Inputs Function
 modbus/function/readExceptionStatus  Fuzzing Read Exception Status Function
 modbus/function/readHoldingRegister  Fuzzing Read Holding Registers Function
 modbus/function/readInputRegister    Fuzzing Read Input Registers Function
 modbus/function/writeSingleCoils     Fuzzing Write Single Coil Function
 modbus/function/writeSingleRegister  Fuzzing Write Single Register Function
 modbus/scanner/discover              Check Modbus Protocols
 modbus/scanner/getfunc               Enumeration Function on Modbus
 modbus/scanner/uid                   Brute Force UID
 modbus/sniff/arp                     Arp Poisoning
SMOD >
Brute Force Modbus UID
SMOD >use modbus/scanner/uid
SMOD modbus(uid) >show options
 Name      Current Setting  Required  Description
 Function  1                False     Function code, Defualt:Read Coils.
 Output    True             False     The stdout save in output directory
 RHOSTS                     True      The target address range or CIDR identifier
 RPORT     502              False     The port number for modbus protocol
 Threads   1                False     The number of concurrent threads
SMOD modbus(uid) >set RHOSTS 192.168.1.6
SMOD modbus(uid) >exploit
[+] Module Brute Force UID Start
[+] Start Brute Force UID on : 192.168.1.6
[+] UID on 192.168.1.6 is : 10
SMOD modbus(uid) >
SMOD >use modbus/scanner/getfunc
SMOD modbus(getfunc) >show options
 UID      None             True      Modbus Slave UID.
SMOD modbus(getfunc) >set RHOSTS 192.168.1.6
SMOD modbus(getfunc) >set UID 10
SMOD modbus(getfunc) >exploit
[+] Module Get Function Start
[+] Looking for supported function codes on 192.168.1.6
[+] Function Code 1(Read Coils) is supported.
[+] Function Code 2(Read Discrete Inputs) is supported.
[+] Function Code 3(Read Multiple Holding Registers) is supported.
[+] Function Code 4(Read Input Registers) is supported.
[+] Function Code 5(Write Single Coil) is supported.
[+] Function Code 6(Write Single Holding Register) is supported.
[+] Function Code 7(Read Exception Status) is supported.
[+] Function Code 8(Diagnostic) is supported.
[+] Function Code 15(Write Multiple Coils) is supported.
[+] Function Code 16(Write Multiple Holding Registers) is supported.
[+] Function Code 17(Report Slave ID) is supported.
[+] Function Code 20(Read File Record) is supported.
[+] Function Code 21(Write File Record) is supported.
[+] Function Code 22(Mask Write Register) is supported.
[+] Function Code 23(Read/Write Multiple Registers) is supported.
SMOD >use modbus/function/readCoils
SMOD modbus(readCoils) >show options
 Quantity   0x0001           True      Registers Values.
 StartAddr  0x0000           True      Start Address.
SMOD modbus(readCoils) >set RHOSTS 192.168.1.6
SMOD modbus(readCoils) >set UID 10
SMOD modbus(readCoils) >exploit
[+] Module Read Coils Function Start
[+] Connecting to 192.168.1.6
[+] Response is :
###[ ModbusADU ]###
  transId   = 0x2
  protoId   = 0x0
  len       = 0x4
  unitId    = 0xa
###[ Read Coils Answer ]###
     funcCode  = 0x1
     byteCount = 1L
     coilStatus= [0]
Link: https://github.com/enddo/smod
