Veganic Posted February 2, 2016 Report Posted February 2, 2016 Hello all, I'm using I'm using QJC24SerialInverter_GW2_V100 library with GX works 2. When I use the function blocks for channel 2 all is well. When I use the function blocks for channel 1 I get an error which points to the following datatype in function block QJC24NoProtocolCh1_FR : CSET_C24_FR. I am assuming that this is a user defined datatype that should be in the library but I an at a loss to work out how to make it work. Has anyone successfully compiled this channel 1 function blocks? How? Thanks. Quote
kaare_t Posted February 3, 2016 Report Posted February 3, 2016 I downloaded the FBs, looks like Mitsu have some problems with this one. I get an error on several FBs. However, the advanced blocks seems to work. Have you tried the advanced FB's? Quote
Veganic Posted February 3, 2016 Author Report Posted February 3, 2016 (edited) Edit: Yes I tried the advanced. Couldn't get it to work for channel 1. I haven't tried the "complex" FBs. Edited February 3, 2016 by Veganic Quote
Gambit Posted February 22, 2016 Report Posted February 22, 2016 After testing I reported the problem to Mitsubishi. They have changed the Library. They still need to test but I have the Lib If you want it. Quote
Veganic Posted February 22, 2016 Author Report Posted February 22, 2016 Do you know when the official update will be up? There is no rush at the moment so I'll try not to trouble you, but thanks for the offer! Quote
Gambit Posted February 22, 2016 Report Posted February 22, 2016 No I do not but the new version is V1.10 Quote
Veganic Posted March 9, 2016 Author Report Posted March 9, 2016 Hi Gambit, The Mitsubishi website is still on version 1.00. Can I trouble you to send me the update? Quote
