PLC siemens 300 with wind monitor
Hi there!
Can someone please tell me where I should put the wind monitor wires at PLC? I have been trying for days to find out.
I have the model 05103L http://www.youngusa.com/Manuals/05103L-90(I).pdf Take a look at page 5 at the dokument. I believe 3 and 4 are suppose to be connected to the PLC, but I dont know where.
I have PLC300 siemens with AI 8 x 13 BIT (331-1KF02-0ab0) and A0 2 x 12 BIT (332-5HB01-0AB0)
I know its suppose to be in AI, but I dont know where at AI.
here are a dokument for PLC 300 siemens.
https://cache.industry.siemens.com/dl/files/629/8859629/att_55794/v1/s7300_module_data_manual_en-US_en-US.pdf
Please help, I have been stuck on this for days.
wire +24 vdc to the black and white wires of the wind speed instrument (WS+, WD+)
wire the red wire to the AI module CH0 I+ terminal (2) wind speed (WS-)
wire the green wire to the AI module CH1 I+ terminal (7) wind direction (WD-)
wire -24 vdc to AI module CH0 + CH1 M- terminals (5,10)
go to hardware config and make sure the analog card CH0, CH1 are set to Current 4-20. I've attached a picture of how your analog card should be configured in HW Config.
Good Luck.
