saakshivaishu Posted February 15, 2016 Report Posted February 15, 2016 (edited) I need basic ideas about CIO Address es. Like Internal inputs and internal output, Actually we are using Cj2m cpu35, In that I need to know the range of internal thatr can be allocated 1)which category instruction it is, 2)What is meant by nA500_13, n4_01, 5.10 etc Edited February 15, 2016 by saakshivaishu Quote
nmlfreitas Posted February 15, 2016 Report Posted February 15, 2016 Your 1 is a comparison instruction, check on the manual..... 1 Quote
Crossbow Posted February 15, 2016 Report Posted February 15, 2016 If you are unfamiliar with ladder logic and Omron addressing, have you checked the Omron website, they offer many e-learning classes which cover PLC basics and CX Programmer. 1 Quote
saakshivaishu Posted February 16, 2016 Author Report Posted February 16, 2016 14 hours ago, Crossbow said: If you are unfamiliar with ladder logic and Omron addressing, have you checked the Omron website, they offer many e-learning classes which cover PLC basics and CX Programmer. Yes I am new to plc programming. I am electronics and communication engineering graduate, Now I have started working in automation company, as a Electrical drawing designer in CAD, Now I know the application that we are going to do with PLC programmer, I am go thoroug hing the standard ,and completed Programs of the Old projects, These are all the doubts I have now, which is necessary for understanding the entire proramming, Other than that greater than or Equal to type of instruction (which I have marked in my Very begging post, I understood and aware of other instructions, So, I will download the attached file of another buddie who previously replied to this post, As you said I will try to follow that ebooks tooo. Thanks for your useful information Quote
saakshivaishu Posted February 16, 2016 Author Report Posted February 16, 2016 16 hours ago, nmlfreitas said: Your 1 is a comparison instruction, check on the manual..... Thanks I will refer that manual Quote
Michael Walsh Posted February 16, 2016 Report Posted February 16, 2016 A little help to get you started: the nA and nD labels are just names that someone has given to a PLC memory address. If you click on the contact or address in an instruction, you will see an address along with the name in a yellow bar near the bottom of your ladder. The others (5.10, D540.00) are all memory addresses that you can find in the manuals above. 1 Quote
saakshivaishu Posted February 17, 2016 Author Report Posted February 17, 2016 4 hours ago, Michael Walsh said: A little help to get you started: the nA and nD labels are just names that someone has given to a PLC memory address. If you click on the contact or address in an instruction, you will see an address along with the name in a yellow bar near the bottom of your ladder. The others (5.10, D540.00) are all memory addresses that you can find in the manuals above. thanks Quote
saakshivaishu Posted February 17, 2016 Author Report Posted February 17, 2016 (edited) I am really happy now, because I read about comparison instruction through instruction help in the software. With out your help it would not be possible all of you. Edited February 17, 2016 by saakshivaishu Quote
