Product:             STEP7 Professional V13
Reference:           FB Declaration Static: Data type TON is not allowed here
Description:
Hi,
I'm using Step7 Prof V13 SP1 upd7 & WinCC Adv V13 SP1 upd7.
In my project I'm using a 312CPU, Article No.: 6ES7 312-1AE14-0AB0, Version: V3.3 & TP1500 Comfort, Article No.:6AV2 124-0QC02-0AX0, Version:13.0.1.0
My Issue:
I've taken previously used FB from my Global library and inserted it into my new Project. In this FB I've declared an IEC Timer (TON) in the static section of the FB. When I go to upload to the PLC after TIA carries out the compilation I get error message 'Data type TON is not allowed here'. I've tried creating a new FB to test and had same issue for CTU,CTD,TOF.
See attached pics
This is really strange as it has always functioned before! Has anyone seen or heard of this issue before?
I'd appreciate any help, Cheers.
Not sure.  I created a FB and just dragged a TON statement into an empty rung from the toolbox on the right.  Told it to make it multi-instance and it compiled with no errors.  CPU is a IM154 ET200S but it should be the same as a 314.  I'll give it a shot with a 312 when i get a chance.
After that i could type in TON as a datatype and it was ok with it.  Maybe you just need to drag the first TON, CTU etc...  into the code to initialize the FB?
Good Luck.
Edited by TravisPedley
