Hey guys, first post!  Friends at Practical Machinist sent me over here b/c we were stumped.
I have a Mitsubishi 500M control CNC machine.  There is a section of the ladders that i don't understand, and Mitsubishi couldn't help, and the OEM is defunct.  I do not have a hardcopy of the ladder circuits.
I have an output , [Y13], that i can't get to turn on because of an internal relay | M453 |       see pic 1
When i searched for relay M453, it seems as if it's in some sort of array function.  see pic 2
None of the relays from M448 thru M512 ever turn on.  I understand that all these are controlled thru this circuit, but i have no clue what is going on with the R registers, and how the heck these internal relays can be turned on.
Can you guys help explain?   Thanks!
Welcome to the Forum,
The value in R2900 is minus 8431 which gives the bit pattern 1101111100010001 this is then MOV 'ed into  internal bit stores (M's).
The instruction [MOV R2900 M448 K4] moves the bit pattern generated by the value in R2900 into M448 through to M463, the K4 is the number of Nybbles (4bit groups) to mov, in this case 4 Nybbles (16 bits).
The question now is, what is actioning and putting the value into R2900?
I hope this helps
Steve
wow thanks man, that makes perfect sense!
I have no clue what is acting on R2900 thru R2903.  When i search R2900, it only comes up with this line seen above.  It seems embedded in another function, i'll have to find it and report back.
