remi_for Posted February 27, 2016 Report Posted February 27, 2016 Hi, Is there anyone who know if there its a way to toggle in TIA V13 sequence step block? I would like to have a light toggle as long is in a step in the sequence? Anyway to do that? Quote
pop29684 Posted March 28, 2016 Report Posted March 28, 2016 Are you using a block from the Siemen library? Quote
TravisPedley Posted March 31, 2016 Report Posted March 31, 2016 I usually set up the clock bits in MB0 Then use the step position to fire your light but put a N.O. clock bit (m0.2 for example) in the rung as well. Quote
