leineme Posted February 28, 2016 Report Posted February 28, 2016 Hi i am trying to connect to omron plc (cj2m ) using modbus tcp/ip , by using the port 502 i get an error saying that the port can't be reached is there any method to fix that or change the port number ? thank you
kaare_t Posted February 28, 2016 Report Posted February 28, 2016 What are you trying to connect with? I get that the Omron PLC is the server ("slave"), but what are you connecting from?
leineme Posted February 28, 2016 Author Report Posted February 28, 2016 hi thank you for the replay i am connecting from my pc, i coded this programm in c# in order to connect to my omron using modbus tcp/ip
kaare_t Posted February 28, 2016 Report Posted February 28, 2016 OK, I'm not very familiar with Omron, but did you set it up as a ModbusTCP server (your C# code is the client right?)? My guess is that you'll need a little setup in the PLC. Again, I'm not very familiar with Omron, but the CJ2M supports ModbusTCP correct (not just RTU)? And as a small side note: Since this basically is an Omron question, you might get more help in the Omron section of this forum instead of the HMI & SCADA section.
leineme Posted February 28, 2016 Author Report Posted February 28, 2016 the plc is the client , my code is the master ..my goal is to be able to read from my plc ( a basic scada/him application ) -yes , it supports the tcp/ip. thanks for the beside note , just because it was said that for modbus tcp/ip communication goes throw 502 ...i just don't know where the plc keep telling me (the port can't be reached ) , i even tried others (random ) and can't be reached also thanks a lot
kaare_t Posted February 28, 2016 Report Posted February 28, 2016 Yes, ModbusTCP uses standard port 502 for communication, so you're good there. If the PLC doesn't respond to any handshakes for 502, you should really check your setup. Many PLC's don't open ports unless you explicitly open them. In other words you must probably configure something in the PLC for it to answer requests.
leineme Posted February 28, 2016 Author Report Posted February 28, 2016 hi , i am sorry i didn't quit catch the meaning of ( configure something in the plc ? ) i thought that was a direct communication : imean code the connexion function , insert the plc's IP @ and the port and using the ethernet cable ..voilà ?
kaare_t Posted February 28, 2016 Report Posted February 28, 2016 As said; I don't know about Omron, but other brands you must configure the device to e.g. allow external devices to connect. Normally the function must be "enabled" or similar just to make sure it's safe. I don't think you'll have to do any programming, but most likely you'll have to enable ModbusTCP. In Mitsubishi you can specify to enable or disable, and you can specify which IP(s) to accept connections from, which ports to use etc. etc. Basically it's the same as opening a specific port and service in your PC's firewall (you don't want to open your PC or PLC to all and everyone by default).
Crossbow Posted February 29, 2016 Report Posted February 29, 2016 This was also asked in the Omron forum, and I replied. CJ2 talks Ethernet/IP not Modbus/TCP.
leineme Posted February 29, 2016 Author Report Posted February 29, 2016 @kaare_t oh now i get what you'r saying i will concider that, thank you so much for the answers
leineme Posted February 29, 2016 Author Report Posted February 29, 2016 @Crossbow please excuse my ignorance first isn't modbus tcp/ip and using ethernet cable is considered as modbus ethernet ? i mean using c# i coded using the modbustcp.dll ? and please would you do me a favor and give me the link to that post ?
kaare_t Posted February 29, 2016 Report Posted February 29, 2016 @leineme No, Ethernet/IP is a different industrial protocol, so they won't work together...
leineme Posted February 29, 2016 Author Report Posted February 29, 2016 i am so confused right now , can i send you the code and tell me whart i am trying to do ? cause i did implement using modbus TCP /IP ? modbusTCP.cs
kaare_t Posted February 29, 2016 Report Posted February 29, 2016 OK, here's a simple explanation: ModbusTCP = Protocol 1 Ethernet/IP = Protocol 2 The difference is that ModbusTCP is a completely different protocol than Ethernet/IP (two different protocols). It's like DNS and DHCP. Two completely different protocols serving two different goals. So you cannot use ModbusTCP if your device only supports Ethernet/IP. So basically DNS != DHCP, and ModbusTCP != Ethernet/IP.
leineme Posted February 29, 2016 Author Report Posted February 29, 2016 oh , no i get that , i was wondering about what exactly the diffrence , i looked in google , but for omron cj2m (i've checked it in their documentation ) they do support modbus tcp/ip via ethernet cable
Crossbow Posted March 1, 2016 Report Posted March 1, 2016 No, they do not. Omron supports Ethernet/IP. It's like trying to talk to someone in Frnech who is speaking German. Show me the document that says they do.
leineme Posted March 1, 2016 Author Report Posted March 1, 2016 CP1W_MODTCP61_manual_en_201111.pdf https://www.myomron.com/index.php?article=1478&action=kb#ModbusTCP https://www.myomron.com/index.php?action=kb&article=1243 + i asked again the director of the factory and he said omron cj2 supports modbus tcp/ip via ethernet cable
Crossbow Posted March 2, 2016 Report Posted March 2, 2016 Your links are about CP1L, not CJ. Someone has written a function block to make a generic Ethernet message that fits the protocol. There is no internal support for communication via the Modbus TCP protocol. You can't just send it a Modbus TCP message. And it's using a CJ1W-ETN21, not the built in Ethernet port. Read the information at the links you just posted, there is a sample.
