help me! i cant connect between hmi & plc
hello all, please help me
hmi model is GS-2107WTBD
plc model is fx2n-32mr
im using gt01-c30r2-6p cable..
i got [ERR. Text]  the SD and RD keep blinking...
do i need to setting the plc parameter?
That cable is wrong.  The R2 means RS232, and the -6P means 6 pin round.  That's for the Q Series.
The FX uses RS422 and its an 8 pin round plug.  You may damage the plug or break pins in your cable.  Cable should be GT01-C30R4-8P for an FX2N built in port.
  • Like 1
yes thx for the information..
i already order the dbsub9 male for 422 connection..
i will update my work..
very2 thx for your reply sir crossbow...
