I see that the GOC is a purely Indian product developed by Mitsubishi in/for the Indian market. I have never seen or used a GOC before and since it's only for the Indian market I think it may be difficult to get help in this forum which is quite international. Please do try, I'm just giving you a small "heads-up".
pls start the goc35 by giving supply
next connect your laptop to goc by ethernet. then you wont get any ip address on it
next you switch off whole goc 35 supply
then leave some 2min
next switch on the goc35 you will get ip address ,gatway, ....etc
then you go to and set ip address in your laptop in codesys software in communication paremeter the local host address
only chang the last three numbers
  • Like 1
POWER ON GOC .
CONNECT MODULE AND PC USING ETHERNET CABLE
PRESS SYSTEM KEY IN GOC FOR 5 SEC(THE KEY BELOW F2).FROM SYSTEM INFO U CAN GET IP ADDRESS.
MAKE SYSTEM IP ON SAME SERIES WITH AN HIGHER DIGIT VALUE IN LAST TWO POUNTS
IN CODESIS INSIDE "CONNUMICATION PARAMETER" GIVE THE SAME IP ADDRESS OF GOC.
  • Like 1
