simonongsk Posted March 10, 2016 Report Posted March 10, 2016 Hi: in Omron there is a command BSET which can be used to set value from DXXXX to DXXXXn. Example BSET #0 D2000 D30000 What is the similar command in Mitsubishi FX3U structure Ladder? thks Quote
Crossbow Posted March 10, 2016 Report Posted March 10, 2016 Don't recall if it's an FX or a Q series command, bu they have one called FMOV (fill move). Quote
Ron_S Posted March 10, 2016 Report Posted March 10, 2016 If you want to zero a range of D registers you can also use ZRST (zone reset) in FX. Quote
