Someone replied to your last post on GOC with a contact at Mitsubishi India.  It's not a product sold outside of India, so I doubt many people on here will be able to help you.
Hello!  You need to define the global variable in PLC_PRG like KEY1_STATUS:BYTE; , this variable you can program as per your required illumination property ( check the help file for different color and flashing code ). While configuring the HMI in HMI config tool, You need to define the property for illumination using the assigned variable.
Regards
Arun
