hi all,
i need help with EXTER T150  HMI urgently we had two panels before and we replaced them with new panels but when we copied the
project file to the flash card the panels don't seem to be able to recognize them, im not familiar with that type of HMI
but the project file consists of folders and files not a single " .cap" or ".dat" file
i checked the manuals but it seem to have something with a software called IX, i need someone with experience to
clarify this point to me
thank you
What panels did you have before? I'm pretty sure you can use E-Designer7 for the T150, but we don't use the same names for the HMIs in Norway (we have "Beijer" and not "Exter" terminals). In any way; how could you copy/paste the project from/to a flash card?
It sounds like you may have the actual project files (source code)
do you have a file ending in .cpa and a folder that contains images and a driver configuration file.
for example...
1 x text file called - "Machine_1_V2.cpa"
1 x folder called -    "Machine_1_V2-Files"  (same name as above but with "-Files" appended to it)
If so you have the project files that can be loaded into Beijer information Designer (I-Designer). Once loaded you can create you own *.dat file to put
on your flash card (or just program the HMI directly using the software).
http://beijerinc.com/product/information-designer/
Alternately if you do not have I-Designer you could post it on this forum (or just to me) me and I will create one for you.
However if you have a project and one of the folders has 50+ files with the extension "DLL" inside the main folder. Then this is probably an IX project for a different HMI
  • Like 1
for example...
THANK YOU FOR YOUR RESPONSE.
I HAVE INFORMATION DESIGNER SOFTWARE BUT THERE ARE NO .CAP OR .DAT FILES, I GUESS IT'S " ix" TYPE..i tried to upgrade the HMI system files
to " ix " but it seems to need a license or special service technique because it's not accepting to be upgraded to " ix" ..only upgrade within the same system files type
  using a flash card reader module connected to PC/LABTOP  via USP
If you have the source code you WILL NOT have a .dat file. You will need to create one.
If you actually show us what files you have we will be better able to help you (otherwise we are just guessing).
Can you upload the files you have for us to see? - or take a screen shot of the files you are talking about.
Edited by Nightfly
On 3/15/2016 at 3:37 PM, Nightfly said:
Hi all,
i had a problem with this HMI really need your help.
i had a ".dat " file, but can i somehow read that file, I mean i need a ".cpa" file instead cause i want to modify something on the project then will save it, load it back to EXTER T150 so next time i can remote access to the HMI from my PC via VNC veiwer software through internet server.Hmm...
or anyone know how to Upload a project from HMI into PC .
thanks a ton pros
Edited 15 Mar 2016 by Nightfly
Hi All,
I'm attempting to replace a T100 with a T150.  I have a .dat on a thumb drive but the T150 doesn't seem to recognize the thumb drive at all.  When I plug it into the T100, I get a request to download the .dat file.  Any thoughts?
On 1/2/2025 at 10:40 AM, Charlie23 said:
Hi All,
I don't think you can do that.  I think you need to open the project in the programming software and change the model.  Pretty sure the compiled DAT file is specific to a certain model, but have not touched these in many years.  They are different resolutions (800x600 vs 1024x768).
