simonongsk Posted March 24, 2016 Report Posted March 24, 2016 hi: in Omron that is a command to count how many bit that are in ON state, any similar instruction in GX Work 2? Thanks Quote
Lambir Posted March 24, 2016 Report Posted March 24, 2016 There is the instruction SUM in FX PLCs. This instruction counts the number of "1" (ON) bits in the data of a specified device. Quote
Theo V Posted March 24, 2016 Report Posted March 24, 2016 Hi Simonongsk, In the dowload section under manuals tutorials I've uploaded the FX3 programming manual. Chapter 12.4 Page 339 tells you more about the SUM instruction. I hope this helps you out. Best regards, Theo V. Quote
