lomaster Posted March 27, 2016 Report Posted March 27, 2016 (edited) Sorry for my english. First missing program and parametrs in Q02CPU. Error 2200. Cause machine long time not use and battery discharged. After change battery and format memory i download project from my frend and appear 3300 error. I dont know which parameter i have to change. How to know? Screenshot37.pdf [Error_code_3300]SP._PARA_ERROR.pdf Edited March 27, 2016 by lomaster Quote
kaare_t Posted March 28, 2016 Report Posted March 28, 2016 Under PLC Parameter and IO Assignement you'll find the IO assignement table. Adjust it to the correct settings for your system to correct this error. 1 Quote
lomaster Posted March 29, 2016 Author Report Posted March 29, 2016 Thanks. One of intelligent function module parametrs in the frends project was setting not correctly. Address wich belong to digital output module. I deleted him. Now everything is ok. Quote
