Hi,
Has anyone got a good work-around for the UK daylight saving hours. Our SNTP server updates but doesn't adjust for daylight saving.
It's an L Series so we use the Time Setting in the PLC parameters.
I just wondered if anyone had a neat way of automatically adjusting for this.
Thanks
Ian
Thanks, GX Developer if possible ?
I can see how it will work if the system is running as DST occurs, but the issue I have is if the system is switched off, then on again after DST has occurred. So you miss the actual change point.
49 minutes ago, ianreeves said:
Thanks, GX Developer if possible?
Sorry, I will make the DST routine in a library form. The libraries are supported by GX IEC Developer or GX Works, GX Developer does not support libraries.
With this routine a time in PLC will be actual always, even at passing DST point it was in stop mode or unpowered.
Sorry... The promised routine is not ready, because I can not already remember, how restrictions to operands has been bypassed at previous time, and at present can not spend a lot of time to find a way. When will be a time, I make attempt to liven up the old HDD.
OK. I had not a time to test the library before publishing. So if something will work wrong, please inform me
27 minutes ago, ianreeves said:
Being stupid how do you import it ? My library files come up as SUL files ?
File with 7z extension is compressed by 7z-archiver, the .sul is inside. So just download the archiver and decompress the file
  • Like 1
