Rakesh M Posted March 31, 2016 Report Posted March 31, 2016 Dear all, I need to develop a PLC program for cycle operation. The logic is as follows : When I/p 1 is ON o/p1 should ON, with a time delay o/p2 should ON ,like wise four outputs should ON , if stop button is pressed the output should stop at the current position ,them again if start is pressed it should resume with that output . Can anyone help me with this logic ?? I am using Q03UDE Cpu..Thankyou.
kaare_t Posted March 31, 2016 Report Posted March 31, 2016 You should try to develop by yourself first, then post what you have done and what isn't working so that we can help you.
Rakesh M Posted March 31, 2016 Author Report Posted March 31, 2016 yes I have developed the logic but the problem is I cannot resume the output from the stopped position
kaare_t Posted March 31, 2016 Report Posted March 31, 2016 Can you upload the code, or isn't that possible?
Rakesh M Posted April 1, 2016 Author Report Posted April 1, 2016 Here is the program backup which I have developed. Project.gxw
kaare_t Posted April 1, 2016 Report Posted April 1, 2016 Try using retentive timers instead (ST). Setup a range of devices in PLC Parameter -> Device (e.g. 1K, start 0 end 1000), rememeber to remove 1K from something else (e.g. Link register from 8K to 7K). Then change all your timers from T to ST with the same numbers (e.g. T0 -> ST0). I haven't tried your specific application in a real CPU but it should do the trick.
Rakesh M Posted April 1, 2016 Author Report Posted April 1, 2016 Thankyou for the reply I will try and let yoy know.
Rakesh M Posted April 5, 2016 Author Report Posted April 5, 2016 I don't know how to use the retentive timers in this can you help me with that.? @Mr.Kaare_t
Crossbow Posted April 5, 2016 Report Posted April 5, 2016 Same as using a timer, but the address will be an ST memory location instead of a T.
