 I am looking to hide screens on a 1020 using an M xx to turn the creen on/off for accessability
but cant  find any animation section similar to TIA
can anyone help
thanks
i want to make the screen accessible by making the screen switch button visible/invisible when the Mxx  changes states
i can do either way just figured it would easier to use a separate screen as all the objects are  controls that are particular to one model
You can try the following script to make something visible when bit (M102 for example) is on.
VISIBLE ON BIT
if([b:M102]==ON)
{my.active = 1;
redraw_object();}
else
{my.active=0;
clear_object(); }
VISIBLE ON BIT
if([b:M102]==ON)
{my.active = 1;
redraw_object();}
else
{my.active=0;
thanks for the response
I am new to using mitsui
how would this be coded into a fx1s processor
would this be as an object script?
Do you know what version of gt designer the script editor became available?  i cant find the editor? looking under Common ?
Edited by dsev
My bad DSev, WLla is correct. Scripts are not available in the 1020/1030. I failed to see that in your original post. But if you ever get to upgrade the HMI to a 2000 equivalent type model there is this Control displaying/hiding option for objects placed on base screens.
Untitled.png.5749b61da974ff933b13afa0425
The effect you require can be achieved by using a pop up window containing your screen switching p/button, this would use a word file 'D' for the pop up not a bit 'M'.
As a start point have a look at the attachment, there will be further steps to refine, but thats the fun of it.
TEST.rar
