Mendon Systems Posted April 5, 2016 Report Posted April 5, 2016 I have one copy of CX Programmer which is giving me a "Net Framework Is Not Installed" message when I try to open a program containing an STL function block. This seems to be similar to an old problem last reported back in 2008 in this thread. http://forums.mrplc.com/index.php?/topic/13409-sfc-not-working-cx-p-v72/&do=findComment&comment=65950 Net Framework 1.1 and 4.6.2 are both installed on this PC and I do not have this problem with any other software. I just noticed this issue a few days ago. I have another nearly identical PC which is set up the same way and does not exhibit this problem. I have just installed the latest updates to CX-One without receiving any error messages but that did not solve the problem. Does anyone have any ideas how to fix this problem without completely removing CX-One and starting over from the original CD?? It seem like this must be something simple like a bad registry entry. Jay?? Michael??
Mendon Systems Posted April 7, 2016 Author Report Posted April 7, 2016 (edited) Well ..... I contacted tech support and got the answer that I expected but did not want to hear. The only way to fix this is to remove CX-One and re-install from the DVD. Edit: After a bit over an hour to remove and re-install CX-One the problem is solved. It seems like a lot of fooling around for a busted link. Edited April 7, 2016 by Mendon Systems fixed
