I recall that the cleanest/recommended method to upgrade firmware was to send the processor to OMRON to perform this change.
This firmware upgrade method may have changed but I am not sure.
Can any OMRON guys shed light on this?
Yes, but Omron's policy is that the user will not do this process (Using DDWin) as there is a potential to make a brick of the controller. Omron will actually sell the firmware already installed on an SD card that comes with a step by step procedure to update the firmware.  This will lessen the likelihood of damaging the processor.
Perhaps I can help ..  I said earlier .."And, I'm going to Omron to get away from Siemens."
This implied no comparison between Omron NJ and Siemens S7-1200 .. they are quite different after all...  However, where they are NOT different, Is the complex and expensive manor that firmware upgrades are performed ...  I think Crossbow thought I was comparing the CPU's  :-)
No, I was not referring to CPU, but to firmware upgrade.  There is typically no need to upgrade firmware in a controller once it is installed.  You buy a CPU because it has the features you need.  You don't plan to update the firmware if the application is already solved.
Only reason to upgrade a working installed CPU is if there is a bug in it.
