Dear everyone,
I would like connect Bar-code Reader to GOT that read Bar-code to input data on GOT 1575 VNTB
Note: Barcode Reader is symbol model & I have use Power electric 5V to nourish
And, I would like confirm that have conflict reverse electric  from Bar-code Reader to GOT or not?
Thanks so much
On 4/11/2016 at 3:14 PM, nguyenthucuc said:
Dear everyone,
Thanks so much
use this setting for barcode with got, also set your barcode with RS232 SETTING.
  • Like 2
@KhurramMehmud If it can connect you could select D destination on PLC that connect with HMI to store data from barcode scanner when read by assign start address and how long for collect data.
On 3/17/2022 at 1:59 PM, KhurramMehmud said:
Hello Everyone,
Can I connect USB port scanner with Mitsubishi GOT2000 ? In GOT2000 System I/F USB are locked
I don't think so.  I think the barcode function was only for the RS232 serial port.  But have not touched on in years, so can't say for certain.
I think the USB ports are for keyboard, mouse, flash drive only...
Sorry late, USB barcode scanner works fine with GOT 2000 at least with GT25 / GT27
CAN I GET THE CABLE PINOUT DETAIL TO CONNECT GS WTBDN HMI TO COGNEX 150 DATA MAN 9 PIN ON RS 232. BECUASE I TRIED STRAIGHT AND CROSS BOTH CONNECTION BUT DID N WORK
RS232 on got has standard pinout:
1-CD, 2-RD, 3-SD, 4-ER, 5-SG, 6-DR, 7-RS, 8-CS, 9 - not connected.
It is important also to configure  GOT so you can use Barcode function.
