shah Posted April 17, 2016 Report Posted April 17, 2016 Hi, i am currently trying to integrate visual studio with advanced HMI tool box to an Omron PLC (cp1h). i am trying to use one of the communication option which is "OmronSerialFinsCom*". But I have no idea how to actually do it. can anybody help me with the setting of the "OmronSerialFinsCom*" properties and where should i download the USB driver for my PLC (cp1h). Thank you in advance. Quote
BobB Posted April 17, 2016 Report Posted April 17, 2016 The USB port is for programming - you will have to install a serial port if the PLC does not have one. You can set up a serial port in the settings tab. Quote
shah Posted April 27, 2016 Author Report Posted April 27, 2016 (edited) Thank you Bob.....My PLC do have a serial port and i have successfully connected my PLC and PC (Com 23). I have a new problem which is how do I identify my I/O address, because im not familiar with omron addressing Edited April 27, 2016 by shah Quote
gclshortt Posted September 5, 2017 Report Posted September 5, 2017 (edited) http://accautomation.ca/omron-cp1h-advancedhmi-communication/ The above URL will show you the addressing for the CP1H using AdvancedHMI. Regards, Garry Edited September 5, 2017 by gclshortt Quote
