Hello!
I am trying to get hold of the bits in a word, i have read that union is the way to go.
My problem is that i cant figure out how union works. I have made a union between a word (16bit) and an array(0...15). The way I understood this was that the word now automaticly updates the array so that when the least significant bit in the word should update array[00] and so on.
This is not happening. When I monitor the variables I can see the word change, but nothing happens with the array.
Have I misunderstood the consept and what should I do to get hold of the bits?
Did you do everything with respect to Unions as I suggested in this post:
Here is my union definition:
Bz4mK8kDuq+PAAAAAElFTkSuQmCC
Here is my variable definition:
1W5ZRiGYRim67DGzDAMwzBBBAtmhmEYhgkiWDAzD
Here is my simulated program (all that I did in simulation was to set on Bit00 of the array):
wM19YpNMzNtZAAAAABJRU5ErkJggg==
Note that the value of UnionTesting.WordVal = 0001 Hex.  As expected, the least significant bit turned on when I set bit 0 on.
You can use a union as an internal variable, but not as an input or output.  So, here is what you do:
Let's say this is your union:
5f772d4ec30ca_UnionDef.jpg.89ea1446cda0f
You could then create an internal variable in the FB that is of the union type like this:
UnionInternal.jpg.27902eb0ee83b20c4baa38
Then you can pass a portion of the union into the FB as an input (Word Input in this case) and map it to the internal union variable, like this:
UnionProg.jpg.f0a8675a34aef7e33b9c53a05e
Then when you use the FB in your code, you just choose the WordLevel portion of the union that you want to input into the FB, like this:
UnionFBUse.jpg.70425d0ded98137042e4c6fb6
