Hi everybody,
I do some projects on wonderware system platform on differents workstations: i work on the same galaxy in many workstations. I imported an object that exist on both workstations A and B  but were renamed on the workstation B . the import was from A to B. now i'm unable to deploy/undeploy the object or delete it :( I try to rename the object in the workstation(galaxy) A and import the object with overwrite/rename options...NO WAY!! I have this errors: Failed to undeploy A: this object AAA won't be undeployed because it doesnt't exist on this engine. However another object BBB exists on this engine and has the same id as the object bein undeployed.
how can i change the id to try?
Thanks
Try to export as aapkg file then delete and reimport
also try unassign then delete
you can do galaxy dump to csv and edit the csv and import using galaxy load
