9pol Posted May 4, 2016 Report Posted May 4, 2016 (edited) I try to use FX3U-ENET-ADAP (Ver 1.22) with FX3U-16M (Ver 3.15) for Ethernet Data Monitoring. I use GX Works2 (Ver 1.98c) to Configure the parameter. The parameter as follow. After write the parameter to PLC and Turn off and on the PLC. I cannot connect to PLC via Ethernet port. And the LED status ERR. on as follow. I try to use Ethernet diagnostics tool to check the problem but no error show as follow. The Connection Status shown "Connecting" and "Disconnected" when I remove a cable. Anyone has experience with these device? Please advise me how to configure the system. Thank You. Edited May 4, 2016 by 9pol Quote
Gambit Posted May 4, 2016 Report Posted May 4, 2016 (edited) Is the Error led flashing or on continuous? If it is flashing than you have a parameter setting error. Maybe it is the port parameters. The 5000 and up are usually used for Mitsubishi Software. So that might be the same as the Melsoft connection (I suggest you try 4000) Edited May 4, 2016 by Gambit Quote
jakey Posted September 6, 2017 Report Posted September 6, 2017 may be RJ45 connecter terminal is not right ? "T568A " or T568B"? Quote
Akahige Posted September 7, 2017 Report Posted September 7, 2017 On 5/4/2016 at 7:03 AM, Gambit said: Is the Error led flashing or on continuous? If it is flashing than you have a parameter setting error. Maybe it is the port parameters. The 5000 and up are usually used for Mitsubishi Software. So that might be the same as the Melsoft connection (I suggest you try 4000) Change the E-net ADP port to 5556. This should fix the routing. F.Y.I. If you had a SFM E-net module that module's port is typically 5551. Quote
