Mitsubishi FX2N talking to Hakko V812SD - problem
Hi All
I'm completely new into Mitsubishi PLC and Monitouch screens.
We had Hakko  V6 screen and we decided to change screen for V812 SD. We converted HMI project from V6 to V8 using V-SFT software but when we tried to run it again we got an error:
Error:142
The I/F driver is not registered.
Error codes manual says:
Transfer the I/F driver. Check the memory of the item.
I'm sure that we transferred the driver. I'm not sure how to check memory of it. Or maybe there is other problem?
PLC model is:
Mitsubishi FX2N-80MR
All advice will be appreciated
Many thanks
