Dear All,
Hi, Im newbie here, please help me to out from my problem. I wanna ask about  "how to add rack in PLC Omron CP1H??" and "How see address Built in AD/DA on Settiing?"
Thanks All
can I get your manual book ? So, Maximum slot in Main Rack CP1H just two?
I have Five  AD041 and One DA041, In Software  Just Two "Empty Slot", Can I add Empty Slot again? and How?
Thanks Jay
Quote
Only two CJ1 modules can be used on Main Rack.
With that amount of analog, it would be better to use a CJ2M processor.
Main rack would be able to support 10 modules.
Up to 3 expansion racks with 10 modules each could be added.
CP1H can be programmed with the Lite version of CX-One.  CJ2 would need the full version of CX-One.
Hope this is helpful.
What are your (complete) number of expansion modules? Does they begin with CP1W ?
And, complete number of the PLC?
Edited by pfort
I dont understand complete number of expansion and start with CP1W, How to Configured All of Them. Pliss your tutorial about that
Thanks
You don't have to use "IO Table and Unit Setup" for CP1W expansion. This is only if you want to add CJ1 modules (2 max).
Section 5 (page 325) for your built-in analog IO, and section 7 (page 389) for expansion units.
15 hours ago, pfort said:
So, In Software I dont have to edit "io table and unit setup"  to input My Expansion Analog Input? h
I just play with CIO Word Address like that Capture?
Edited by iqrom
I did not pay attention enough before to your quantity of AD041 (5) and gtsupport was right of course.
You can not have more than 3 of them because you are limited to 15 inputs words, and they need 4 input words each.
my omron plc is of npn type that means common -ve .. if accidently connect another -ve terminal which is anoutput from a sensor (-24v). if there is any problam for that.....
Hello Experts!
I have a question. I have one module MAD42. Im going to add one more extra connected to the first one. How to set the input configuration for second module? I can't figure out exactly
how to set configuration for second Analog card. For the second card i should move for example #80ED to 104 and 105? Than read the input from 6 to 10?
  mad42.thumb.JPG.a4bec5a10caf00bf0c4dab84
We need to understand your configuration.
Do you have two CP1W-MAD42 modules?
Or are they CJ1W-MAD42?
Thanks,
gtsuport
Thanks,
gtsuport
CP1W-MAD42 . I have one but I going to connect another one. I need more than 4 analog inputs. 8 Inputs should be enough.
