arsaam Posted May 20, 2016 Report Posted May 20, 2016 hi all, i have ploblem for upload from plc &occre this error please help my plc is modicon tsx compact 984-285 Quote
Quant Posted May 20, 2016 Report Posted May 20, 2016 Hello arsaam, I' not sure, but maybe your plc have LL984 firmware, so you can't upload you IEC application in to this plc now. You just need the right IEC firmware for your plc. The sutable firmware you will find in c:/concept/Dat Quote
arsaam Posted May 22, 2016 Author Report Posted May 22, 2016 (edited) hi all, if The exportable code (machine code) loaded in plc, can i uplaod this cod? & load in another plc {Process for loading Loading the PLC can take place in two parts: 1. The exportable code (machine code) is always loaded onto the PLC. 2. The complete compressed user program is loaded onto the PLC Note: The user program, consisting of user defined EFBs, DFBs, derived data types and the program (variables, sections, etc.), is only loaded onto the PLC if in dialog Options for generating codes (Project → Options for generating codes...) check box contain IEC selection information was activated beforehand. The option to also load the comments contained in the check box onto the PLC, thereby making them available as selection information, is available, as well. During selection the entire user program can be transferred from the empty project to the programming device.} Edited May 22, 2016 by arsaam Quote
Quant Posted May 23, 2016 Report Posted May 23, 2016 If your plc doesn't contain upload information (just machine code) then you will be not able to upload anything ;( Quote
