Can anyone direct me to the Mitsubishi Function Block library for GXWorks2?
The manuals say its on the website but I can't find it.
Both. Particularly those for controlling the A800 VSD's using CC Link IE on the Q series PLC with a QJ71GF11-T2 master
I have an A800 on CC-Link IE Field (Q master) here which is controller by a GOT. You really don't need a FB as it is very easy.
What questions do you have?? You only need to set up two parameters in the A800 drive and set the inverter in the CC-Link IE Field parameters.
Thanks. I just want to start/stop, change speed of the VSD and monitor any alarms. I've read the FR-A8NCE UM.pdf manual (attached) but it seems more complex than needed. (or maybe I'm reading more into it than needed?) A typical programming example I expect to use is 8.7 in the manual.
As I understand it config the VSD,
Pr.434=Network No (on my system=1)
Pr.435=Station No of the VSD(starts at 21-)
I will have 13 VSD's on the network. 3 added so far.5744461c4dec5_CCIEVSD.thumb.JPG.10a3b2a8
