HELLO EVERYONE,
CURRENTLY I AM WORKING ON FX3U PLC. FOR MY PROJECT WE NEED 2 ANALOG OUTPUTS SO WE BOUGHT FX2N-2DA MODULE. I ALREADY READ THE MANUAL FOR  FX2N-2DA PROGRAMMING BUT I DIDNT GET SATISFACTORY THING FROM THAT:-(.
PLEASE HELP ME IN THIS . JUST SHOW ME THE PROPER PROGRAMMING FOR FX2N-2DA MODULE FOR 0-10V DC. ANY SCREENSHOTS OR MANUAL OR ANYTHING.
Thanks for the reply... I am using GXWorks2 version 1.87R
I already read that manual but i am not able to understand the example given in that. Please if you have any another manual or example then send me..
thanks
Edited by SHIV121
Attached is a Mitsubishi made FB for the FX2N-2DA unit.
The FB is made in GX IEC Developer but should import to GX Works without any problem.
This should hopefully solve your problem
FX2N-2DA.zip
Hey,,,, thanks Bryll for your support. :-)
But i also got the configuration of FX2N-2DA in ladder format also. And it looks easier.
I will try both of it.
The function block gives you everything you need, it's quite simple to use.
fx2n-2da.jpg.4e888a0b683d641e5d1bb1fa35c
"Special_Module_Position" - If this is the first unit to the right of the cpu, write 0, second unit = 1, and so on.
"Analog_Value_Ch1" - Your analog value (0-4000) that represents the output of 0-10VDC at the output.
"Analog_Value_Ch2" - Same as above, but for channel 2.
"Module_In_Operation" - Don't think this one needs any explanation.
Compile and download, but don't forget to give the block an instance.
