onboardx Posted May 25, 2016 Report Posted May 25, 2016 Hi. I will use FX3U-4AD-PT-ADP, FX3U-4DA-ADP modules in my program but I didn't configure in Gx Works 2. Which section is used to setup in GX Works 2? Quote
Crossbow Posted May 25, 2016 Report Posted May 25, 2016 You don't configure anything, it's automatic. Read the manual, it clearly states the addresses defined for each module on the left side bus. Every left side bus module has addresses already allocated inside the CPU. Quote
Bryll Posted May 26, 2016 Report Posted May 26, 2016 Look for addresses D8260-D8279 chapter 37.2.19 "Analog special adapters" in the manual (FX3G/FX3U/FX3UC series programmable controllers) and you will find what you are looking for Quote
