Dear all,
Does anyone have a NTXS verion 1.03? I can only find ver 1.04 in the internet.
I am having a trouble while replacing NT3S-ST124B-E. The old one is using RS422 Communication. using a 5 cable in pin 1, 4,5,8, and 9. But it can not communicate after i download the old program I uploaded(firmware ver 1.03) to the new unit (firmware ver 1.04). it keep saying com 1 Communication Error.  From the manual NTXS software, I discovered that the communication driver supposed to be downloaded together with the firmware.
I used this cable RS-232 connection for programming (upload /download) and it works perfectly fine:
db 9 Male (NT3S-ST124B-E) to db 9 female (PC)
2 to 2
3 to 3
5,9 jumper to 5
The program i managed to upload using NTXS 1.04 in Win 7 32 bit and sucessfully download to the new NT3S in Win XP 32 bit (tried so many times but it fails on Win 7 32 bit). The program says that the NT3S is connected to CJ1 PLC.
The cable used to connect to the old NT3S is using Pin 1,4,5,8,9 which means it should be RS422 (Xtra Drive).
I wanted to try using version 1.03 but I can not find it.
Regards,
Budianto
Scanner NT3S.pzm
Could you please provide the firmware for NT3S-ST124B-E?
My equipment says that I need to download the firmware, but i can't find it.
Thanks in advance
Edited by PLCforall
Thanks in advance
On 16.06.2019 at 4:48 PM, Parviz said:
i need firmware for NT3S-S126B-E
thank
If you run NTXS As administrator, the firmware will download to HMI without errors.
