vanquangtk Posted May 31, 2016 Report Posted May 31, 2016 Hello every one I got a trouble with Omron Sysmac,when connecting with NX-ECC201.My NX-ECC201 include 2 module NX-ID and 2 module NX-OD. I got the error "Slave Application Error" with it Do you know how I can solve this error. Thank you so much Quote
MotionControl.CAT Posted June 9, 2016 Report Posted June 9, 2016 Hi, NX_ECC* is an EtherCAT Adapter for NX I/O, and you have 'simple' Input and Output Cards, so the probability of having an error in the configuration of the NX I/O is really low... as there's few to configure..., so... I'd point to the NX-EC coupler itself configuration. The 'Slave Application Error' is a 'generic' EtherCAT Error, so please you should provide more details on the error from the troubleshooter function in Sysmac, I'd check the basics... that the ECC coupler configuration mathces with the hardware, that the version of the units matches, etc..., I'm sure you'll fix the problem quick, because you are not using hardware that requires advanced configuration Quote
ParaffinPower Posted June 9, 2016 Report Posted June 9, 2016 The 'backplane' connection with the Nx I/O is rubbish. I had endless problems with a system. This was one of the million errors that would randomly appear. Omron recommend cleaning the contacts and fitting clamps either end to hold it together. Of course, ether cat is not a silver bullet and all usual noise mitigation techniques are required. Pp Quote
vanquangtk Posted June 9, 2016 Author Report Posted June 9, 2016 Hello, Thank you every one for your help. I already fixed that problem by following steps in this link https://www.myomron.com/index.php?article=1607&action=kb Quote
