MadAit Posted June 14, 2016 Report Posted June 14, 2016 Hi all I am using an old mitsubishi plc to read alogic inputs comming from 8 channel modul. I set the dip switches so thas i use 0 to 10 v inputs. And to read the value of the channel i used the 'from' instruction however no thing comes from the channel on the monitor mode I any one has an idea i will be very great full if he helps me Thanks for all
Luke.S Posted June 14, 2016 Report Posted June 14, 2016 I'm pretty sure you need to set the "convertion enable" bits for the channels you are using with a TO command if you haven't already. There should be an example of this program in the manual for that module if you google it.
MadAit Posted June 14, 2016 Author Report Posted June 14, 2016 In fact you may be right LUKE. s i just used the From instruction i did not use the TO. I will try this and give you a feed back Thanks
MadAit Posted June 14, 2016 Author Report Posted June 14, 2016 (edited) 3 hours ago, MadAit said: Hi I am using A1s plc with a1s68ad module Edited June 14, 2016 by MadAit
