kaare_t Posted June 14, 2016 Report Posted June 14, 2016 Which GX Developer version? Which error? Screenshot of problem?
JanHrust Posted June 14, 2016 Report Posted June 14, 2016 If you have skype installed, kill it in the task manager. I have encountered that it can cause some problems.
untusoft Posted June 15, 2016 Author Report Posted June 15, 2016 Still same problem, this problem appear when starting registering USB and GOT on the Installation process.
Inntele Posted June 16, 2016 Report Posted June 16, 2016 This is due to incompatibility between your current OS version with the version for which the software has been written. It can be fixed. I do it manually: 1. Clean the PC with CCleaner to delete temp files and to clean the windows registry. 2. Make a copy of GX Developer installator on a hard disk, then operate with this copy. 3. Consistently opening the installator folders, find the executable files in each folder. 4. Select the executable file and open a context menu with a right button. 5. Choose the "Fix the compatibility issues" item, then follow with the tool instructions. Take in account, you do not have to run the executable file, only to confirm that the issue has been fixed and to save the file with a new parameters! 6. After you make the procedure for all executable files of the installator, the you can run the installation and the installation process should be finished completely without any troubles.
Ram sharma Posted October 7, 2023 Report Posted October 7, 2023 (edited) Please tell me anyone when I install gx developer. This error show. How to fix it's problem. Edited October 7, 2023 by Ram sharma
Crossbow Posted October 9, 2023 Report Posted October 9, 2023 On 10/7/2023 at 8:17 PM, Ram sharma said: Please tell me anyone when I install gx developer. This error show. How to fix it's problem. As it says, make sure the user logged into Windows has full admin rights before trying to install. Likely this user does not so the installer cannot modify something it needs to.
VeeB Posted October 10, 2023 Report Posted October 10, 2023 Version 8.91V is very, old stuff Beter to use the latest version for installation on Window 8https://www.mitsubishielectric.com/fa/download/software/cnt/plc/index.html
