sttchui Posted June 18, 2016 Report Posted June 18, 2016 Hi, anyone can recommend for Melsoft for Q series instruction to reverse the ASCII code i receive the eg. bacode ABC12345 i wanted to change the code 54321CBA TO DISPLAY ON OTHER SCREEN THANK YOU! Regards sttchui Quote
Inntele Posted June 18, 2016 Report Posted June 18, 2016 1. What is the full name of CPU? 2. What PLC module do you use to get the ASCII-code from barcode reader? Quote
sttchui Posted June 18, 2016 Author Report Posted June 18, 2016 i using Q03UDECPU, i used Q03UDECPU port to pull the data from another computer, but the ASCII receive is all reverse Quote
Inntele Posted June 18, 2016 Report Posted June 18, 2016 Look toward the use of STRINS instruction sequence Quote
